Help with unstable ADC
Hi there, I am trying to measure tank levels with a pressure sensor and have wired in a Voltage Divider to ADC on a ESP WT32-ETH1. I believe this is a WT32-S1 chip.
Is there any way I can clean up the noise on the ADC?
The ADC seems really unstable and fluctuates a lot.
21:42:32][D][sensor:094]: 'Water Tank Level': Sending state 0.22436 % with 0 decimals of accuracy
[21:42:33][D][sensor:094]: 'Water Tank Level': Sending state 0.39606 % with 0 decimals of accuracy
[21:42:34][D][sensor:094]: 'Water Tank Level': Sending state 0.23657 % with 0 decimals of accuracy
[21:42:35][D][sensor:094]: 'Water Tank Level': Sending state 0.40323 % with 0 decimals of accuracy
[21:42:36][D][sensor:094]: 'Water Tank Level': Sending state 0.13882 % with 0 decimals of accuracy
[21:42:37][D][sensor:094]: 'Water Tank Level': Sending state 0.34237 % with 0 decimals of accuracy
[21:42:38][D][sensor:094]: 'Water Tank Level': Sending state 0.07500 % with 0 decimals of accuracy
  - platform: adc
    pin: GPIO34
    name: "Water Tank Level"
    update_interval: 1s
    attenuation: auto
    unit_of_measurement: "%"
    accuracy_decimals: 0
   filters:
   - median:
       window_size: 15
       send_every: 4
   - delta: 0.1
   - calibrate_linear:
        datapoints:
         # Map 0.0 (from sensor) to 0.0 (true value)
         - 0.00 -> 0
         - 0.95 -> 15
         - 3.30 -> 100
0.2% fluctuation is not a lot.
If you set the decimals to 0 and delta 0.1 you shouldn’t see any changes below 3% on your filtered values.
Which is good enough resolution for that kind of sensor.
