Hi Guys, need some help with my setup.
Originally, i had the Nortek Linear HUSBZB-1 zigbee/zwave stick with my HomeAssistant. I used the HUSBZB-1 for Zwave, while i used the CC2531 for zigbee2mqtt and it worked quite well with the following ports in use:
- CC2531 on /dev/ttyACM0
- HUSBZB-1 on /dev/ttyUSB0 (zwave) and /dev/ttyUSB1 ( zigbee - but not configured since i use z2m)
A few months later, I started getting poor coverage on the CC2351 stick, so i just upgraded to the newer CC2652RB flashed with the latest firmware, but the problem is it’s being detected on /dev/ttyUSB0, now the HUSBZB stick is no longer being detected.
Is there any way to change the ports that the HUSBZB uses to maybe /dev/ttyUSB1 and /dev/ttyUSB2?
