Hi, I’m after some help regarding something related to power.
I am somehow measuring around 100 - 150VAC across my AC phase and DC negative. I have checked to see if I have accidentally linked my Negative with my Neutral, but I have no continuity between them.
If I measure AC across the AC phase, and DC negative, I am getting like around 100 + VAC.
Having said that, everything on the 12VDC power supply works as expected, the only way I noticed this was getting a slight tickle on the DC negative.
I have a few of these cabinets around the place and this is the only one with this issue.
I have eliminated any possibility of a faulty power supply, and even with all the negatives disconnected, I am still getting AC on my negative, I cannot work out how this is happening. The only thing I can think of is a bad earth on the AC side. I have literally disconnected everything on the DC side by splitting ALL neutrals and still, I get AC across my Negative.
Any ideas or tips would be great.
Try save me the whole “you’re not a sparky spiel”
