I’m trying to send an API request using XML to a Hikvision camera. I have it working with a simple request, but I can’t get it to work with a more complex request.
This is the output when sending a GET request for the simple request:
<?xml version="1.0" encoding="UTF-8"?>
<Shutter version="2.0" xmlns="http://www.hikvision.com/ver20/XMLSchema">
<ShutterLevel>1/25</ShutterLevel>
</Shutter>
I send the following PUT command via the shell command which works perfectly:
curl -s --basic "http://user:[email protected]/ISAPI/Image/channels/1/shutter" -X PUT -H "Content-Type: text/xml; charset=UTF-8" -d "<?xml version="1.0" encoding="UTF-8"?><ShutterLevel>1/25</ShutterLevel>"
This is the output from the more complex request:
<VideoOverlay version="2.0" xmlns="http://www.hikvision.com/ver20/XMLSchema">
<normalizedScreenSize>
<normalizedScreenWidth>704</normalizedScreenWidth>
<normalizedScreenHeight>576</normalizedScreenHeight>
</normalizedScreenSize>
<attribute>
<transparent>false</transparent>
<flashing>false</flashing>
</attribute>
<TextOverlayList size="4">
<TextOverlay>
<id>1</id>
<enabled>true</enabled>
<positionX>670</positionX>
<positionY>352</positionY>
<displayText>*********My Text Here*********</displayText>
<directAngle></directAngle>
</TextOverlay>
</TextOverlayList>
<DateTimeOverlay>
<positionX>572</positionX>
<positionY>576</positionY>
<dateStyle>DD-MM-YYYY</dateStyle>
<timeStyle>12hour</timeStyle>
<displayWeek>false</displayWeek>
</DateTimeOverlay>
<channelNameOverlay>
<enabled>false</enabled>
<positionX>512</positionX>
<positionY>64</positionY>
<name></name>
</channelNameOverlay>
<fontSize>adaptive</fontSize>
<frontColorMode>customize</frontColorMode>
<frontColor>ffffff</frontColor>
<alignment>allRight</alignment>
<boundary>1</boundary>
<upDownboundary>0</upDownboundary>
<leftRightboundary>0</leftRightboundary>
</VideoOverlay>
I’m trying to change the displaytext under textoverlay. I’ve tried so many variations, but no bueno. I’ve even tried using a single line converter to convert the whole output to a single line and send that, but that doesn’t work. It works if I edit the output from the GET request then send it back as a PUT request.
