Help with Yale Linus Smart lock automation
I just did an automation which opens the lock when a home assistant user arrives to home zone and sends tts to Google speaker.
We’ll see if it works when that person arrives to home zone.
But the example would make things a lot simpler. Maybe.
This automation worked beautifully.
When a HA user with companion app arrives to the Home zone, the lock opens and the google speaker announces that “user” arrives.
This automation opens the lock earlier than the Yale app itself, because that needs the users device to connect to the same wifi/BT as the lock.
So now I need to make the automation for all of the users, but duplicating the original does the trick.
This thread is so confusing. Similar usernames, marked solution that does not show a solution, and huh???
