Hi
I’m new to Home Assistant and trying my best to solve problems before posting. I’ve tried searching here for help but can’t find a fix to this issue.
I’ve installed Mosquitto broker intergration and Zigbee2mqtt (1.18.1-1) both are configured and a MQTT user set up. I’ve set up a new install of home assistant with latests updates. I’ve no other zigbee intergrations installed. My zigbee stick is a conbee ii.
When I visit Zigbee2mqtt on the sidebar to search and pair new devices it shows a loading please wait message for a moment then " Loading devices takes too long time.
Consider reading documentation"
I’ve adding the webbased frontend configuration suggested previously but I just get bad gateway error.
my Zigbee2mqtt config and log file are posted below seperated by **** so its not one long confusing post
The log file isn’t showing any errors and I’m lost what to try next so any help is much appreciated.
zigbee2mqtt config
data_path: /config/zigbee2mqtt
external_converters:
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: true
mqtt:
base_topic: zigbee2mqtt
server: mqtt://192.168.86.78:1883
user: mqttuser
password: mqttpass
serial:
adapter: deconz
port: >-
/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2434459-if00
advanced:
log_level: warn
pan_id: 6754
channel: 11
network_key:
- 1
- 3
- 5
- 7
- 9
- 11
- 13
- 15
- 0
- 2
- 4
- 6
- 8
- 10
- 12
- 13
availability_blocklist:
availability_passlist:
device_options: {}
blocklist:
passlist:
queue: {}
frontend:
port: 8099
experimental: {}
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: ‘-d -d’
log: false
Log file
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] socat.sh: executing…
[19:16:57] INFO: Socat not enabled, marking service as down
[cont-init.d] socat.sh: exited 0.
[cont-init.d] zigbee2mqtt.sh: executing…
[19:16:58] INFO: MQTT available, fetching server detail …
[19:16:58] INFO: Previous config file found, checking backup
[19:16:58] INFO: Creating backup config in ‘/config/zigbee2mqtt/.configuration.yaml.bk’
[19:16:58] INFO: Adjusting Zigbee2mqtt core yaml config with add-on quirks …
[cont-init.d] zigbee2mqtt.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[19:16:59] INFO: Handing over control to Zigbee2mqtt Core …
[email protected] start /app
node index.js
CREATED DECONZ ADAPTER
Zigbee2MQTT:warn 2021-07-30 19:17:04:permit_join
set totrue
in configuration.yaml.
Zigbee2MQTT:warn 2021-07-30 19:17:04: Allowing new devices to join.
Zigbee2MQTT:warn 2021-07-30 19:17:04: Setpermit_join
tofalse
once you joined all devices.
**** Text
