"data": {
"versionInfo": {
"driverVersion": "10.22.2",
"serverVersion": "1.28.0",
"minSchemaVersion": 0,
"maxSchemaVersion": 28
"entities": [
"domain": "switch",
"entity_id": "switch.multisound_indoor_siren",
"original_name": "",
"original_device_class": null,
"disabled": false,
"disabled_by": null,
"hidden_by": null,
"original_icon": null,
"entity_category": null,
"supported_features": 0,
"unit_of_measurement": null,
"value_id": "26-37-0-currentValue",
"primary_value": {
"command_class": 37,
"command_class_name": "Binary Switch",
"endpoint": 0,
"property": "currentValue",
"property_name": "currentValue",
"property_key": null,
"property_key_name": null
"state": {
"nodeId": 26,
"index": 0,
"installerIcon": 3840,
"userIcon": 3840,
"status": 4,
"ready": true,
"isListening": true,
"isRouting": true,
"isSecure": false,
"manufacturerId": 305,
"productId": 10,
"productType": 4,
"firmwareVersion": "1.15",
"zwavePlusVersion": 1,
"deviceConfig": {
"filename": "/data/db/devices/0x0131/ph-pse02.json",
"isEmbedded": true,
"manufacturer": "Zipato",
"label": "PH-PSE02",
"description": "Multisound Indoor Siren",
"devices": [
"productType": 4,
"productId": 10
"firmwareVersion": {
"min": "0.0",
"max": "255.255"
"preferred": false,
"paramInformation": {
"_map": {}
"interviewAttempts": 1,
"endpoints": [
"nodeId": 26,
"index": 0,
"userIcon": 3840,
"deviceClass": {
"basic": {
"key": 4,
"label": "Routing Slave"
"generic": {
"key": 16,
"label": "Binary Switch"
"specific": {
"key": 5,
"label": "Siren"
"mandatorySupportedCCs": [
32,
37,
133,
89,
128,
114,
115,
134,
94
"mandatoryControlledCCs": []
"commandClasses": [
"id": 37,
"name": "Binary Switch",
"version": 1,
"isSecure": false
"id": 133,
"name": "Association",
"version": 2,
"isSecure": false
"id": 89,
"name": "Association Group Information",
"version": 1,
"isSecure": false
"id": 114,
"name": "Manufacturer Specific",
"version": 2,
"isSecure": false
"id": 115,
"name": "Powerlevel",
"version": 1,
"isSecure": false
"id": 134,
"name": "Version",
"version": 2,
"isSecure": false
"id": 94,
"name": "Z-Wave Plus Info",
"version": 2,
"isSecure": false
"id": 90,
"name": "Device Reset Locally",
"version": 1,
"isSecure": false
"id": 152,
"name": "Security",
"version": 1,
"isSecure": true
"id": 122,
"name": "Firmware Update Meta Data",
"version": 2,
"isSecure": false
"values": [
"endpoint": 0,
"commandClass": 37,
"commandClassName": "Binary Switch",
"propertyName": "currentValue",
"ccVersion": 1,
"metadata": {
"type": "boolean",
"readable": true,
"writeable": false,
"label": "Current value",
"stateful": true,
"secret": false
"value": false
"endpoint": 0,
"commandClass": 37,
"property": "targetValue",
"propertyName": "targetValue",
"ccVersion": 1,
"metadata": {
"type": "boolean",
"readable": true,
"writeable": true,
"label": "Target value",
"valueChangeOptions": [
"transitionDuration"
"stateful": true,
"secret": false
"value": false
"endpoint": 0,
"commandClass": 114,
"commandClassName": "Manufacturer Specific",
"property": "manufacturerId",
"propertyName": "manufacturerId",
"ccVersion": 2,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Manufacturer ID",
"min": 0,
"max": 65535,
"stateful": true,
"secret": false
"value": 305
"endpoint": 0,
"property": "productType",
"propertyName": "productType",
"ccVersion": 2,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Product type",
"min": 0,
"max": 65535,
"stateful": true,
"secret": false
"value": 4
"endpoint": 0,
"property": "productId",
"propertyName": "productId",
"ccVersion": 2,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Product ID",
"min": 0,
"max": 65535,
"stateful": true,
"secret": false
"value": 10
"endpoint": 0,
"commandClass": 134,
"commandClassName": "Version",
"property": "libraryType",
"propertyName": "libraryType",
"ccVersion": 2,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Library type",
"states": {
"0": "Unknown",
"1": "Static Controller",
"2": "Controller",
"3": "Enhanced Slave",
"4": "Slave",
"5": "Installer",
"6": "Routing Slave",
"7": "Bridge Controller",
"8": "Device under Test",
"9": "N/A",
"10": "AV Remote",
"11": "AV Device"
"stateful": true,
"secret": false
"value": 3
"endpoint": 0,
"property": "protocolVersion",
"propertyName": "protocolVersion",
"ccVersion": 2,
"metadata": {
"type": "string",
"readable": true,
"writeable": false,
"label": "Z-Wave protocol version",
"stateful": true,
"secret": false
"value": "4.38"
"endpoint": 0,
"property": "firmwareVersions",
"propertyName": "firmwareVersions",
"ccVersion": 2,
"metadata": {
"type": "string[]",
"readable": true,
"writeable": false,
"label": "Z-Wave chip firmware versions",
"stateful": true,
"secret": false
"value": [
"1.15",
"1.8"
"endpoint": 0,
"property": "hardwareVersion",
"propertyName": "hardwareVersion",
"ccVersion": 2,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Z-Wave chip hardware version",
"stateful": true,
"secret": false
"value": 1
"isFrequentListening": false,
"maxDataRate": 100000,
"supportedDataRates": [
40000,
100000
"protocolVersion": 3,
"supportsBeaming": true,
"supportsSecurity": false,
"nodeType": 1,
"zwavePlusNodeType": 0,
"zwavePlusRoleType": 5,
"deviceClass": {
"basic": {
"key": 4,
"generic": {
"key": 16,
"specific": {
"key": 5,
"label": "Siren"
32,
37,
133,
89,
128,
114,
115,
134,
94
"interviewStage": "Complete",
"deviceDatabaseUrl": "https://devices.zwave-js.io/?jumpTo=0x0131:0x0004:0x000a:1.15",
"statistics": {
"commandsTX": 106,
"commandsRX": 40,
"commandsDroppedRX": 0,
"commandsDroppedTX": 0,
"timeoutResponse": 34,
"rtt": 31.4,
"rssi": -65,
"lwr": {
"protocolDataRate": 3,
"repeaters": [],
"rssi": -67,
"repeaterRSSI": []
"highestSecurityClass": -1,
"isControllerNode": false,
"keepAwake": false
