Would anyone be able to assist with my code, I would like to work out how many days there are between the current date and the data specified in my input_datetime helper.
The code below seems to give me a correct answer however the output is:
2 days, 15:13:27.207750
How would I go about cleaning up the output so it just gives me the “2” and drops the rest.
{% set duedate = now().fromtimestamp(state_attr('input_datetime.rubber_plant_feed_date', 'timestamp')).astimezone() %}
{% set currentdate = now().astimezone() %}
{% set days = currentdate - duedate %}
{{days}}
The result (i.e., days) is a Python timedelta object. That object has a total_seconds() method, which, of course, returns the total number of seconds the delta represents. If you use that you can divide by the number of seconds in a day, then round or whatever.
{% set days = (now() - now().fromtimestamp(state_attr('input_datetime.rubber_plant_feed_date', 'timestamp')).astimezone()) | string %}
{{ days.split()[0] if 'day' in days else 0 }}
EDIT
If rubber_plant_feed_date is typically a future date then reverse the order of the subtraction (otherwise the result will be a negative value).
