Help!!! It is necessary to find out the last date of the full charge of the battery, up to more than 99%, using long -term statistics, including. The data is obtained with breaks (the sensor readings are incomplete, sometimes the device is disabled).
Thank you!!!
Thanks for the answer!!
If I understood correctly, this sensor and trigger does not use statistics and in the work it is necessary to be in line data. Is it possible to get the necessary date using long term statistics!
Thanks for the hint, you can get the necessary data in real time.
If I understand correctly, your sensor and trigger do not use statistics in work. Your sensor changes at the time of full charge of the battery using the state: “{Now ()}}”.
Is it possible to request already collected data to receive a date.
