Team,
In quite a few scenarios I use helpers to combine values of several entities. (“SUM”)
shelly_officedesk_power
shelly_officeac_power
shelly_officeequipment_power
If one of these sensors becomes unavailable:
the helper becomes unavailable, otherwise it nicely shows the sum value.
As a result I cannot use the GUI and have to revert to YAML confuguration:
template:
- sensor:
- name: "Electricity OFFICE Total"
unit_of_measurement: "kWh"
state: >
{{ (states('sensor.shelly_officedesk_power') | float(0) + states('sensor.shelly_officeac_power') | float(0) + states('sensor.shelly_officeequipment_power') | float(0) ) | round(1) }}
With the YAML config the ‘fallback value’ of these entities is 0 (| float(0)
All of the other settings of this helper do seem to deal with the unavailable sensor: Minimum, Maximum, Arithmetic mean, median, most recently updated, statistical range
, except for sum
Would it make sense that a SUM helper ignores “unavailable” entities in its configuration?
