I am totally new here and this may be a simple questions to answer.
However, I hope someone can help me with this as so far I had no luck with my research on a solution.
I have created a virtual helper switch (boolean) that I can toggle (on/off) from my dashboard.
However, instead of showing “on/off” for the current state, I would like to show a custom state, like “enabled/disabled” (just an example).
Is there a way to change the state attributes for such a helper?
You’ll need to explain your application in greater detail.
I don’t understand why you wanted to make an Input Boolean’s states ‘enabled/disabled’ when it doesn’t even display its states as text in a dashboard view.
