I’m very close at giving up with this board and esphome has anyone had any luck with it?
here is my config
esphome:
on_boot:
priority: 900
then:
- output.turn_off: vext_pin #(GPIO45 LOW = ON)
- output.turn_on: lora_cs_pin lora CS (HIGH)
- output.turn_on: lora_reset_pin # Hold LoRa RESET (LOW)
- delay: 100ms
output:
- platform: gpio
pin: GPIO45
id: vext_pin - platform: gpio
pin: GPIO8
id: lora_cs_pin - platform: gpio
pin: GPIO12
esp32:
board: esp32-s3-devkitc-1
framework:
#type: esp-idf #tried both solutions
type: arduino
Enable logging
logger:
web_server:
ota:
- platform: esphome
password:
wifi:
ssid: !secret wifi_ssid
font:
- file: “gfonts://Roboto”
spi:
clk_pin: GPIO3 # CLK
mosi_pin: GPIO1 # SDI
miso_pin: GPIO2 #tried swapping GPIO1-2
display:
- platform: waveshare_epaper
spi_id: bus_a
cs_pin: GPIO4 # Eink-CS
dc_pin: GPIO5 # D/C
reset_pin: GPIO6 # Eink-RST
#busy_pin: GPIO7 # Eink-BUSY
#model: 2.13in
busy_pin:
number: GPIO7
inverted: true #tried both true and false
model: 2.13in-ttgo-dke #tried 2.13inv3 and 2.13inv2
rotation: 0°
reset_duration: 10ms
spi_mode: MODE0
full_update_every: 1
update_interval: 15s
lambda: |-
it.fill(COLOR_OFF);
it.rectangle(0, 0, 121, 249, COLOR_ON);
it.print(10, 10, id(font_small), “V1.2 FACTORY FIX”);
