Heltun Heating Thermostat - can't set parameters using automations
Hi
I have 2 Heltun Heathing Thermostats which I can manage using the UI, mean I can set temp or mode such as heating/away etc.
However when I try the same in an automation it get executed without an error but nothing happens.
For instance I try the following:
Set Value of Config Parameter 9 (input/output config) to the value 5 (Away), nothing happens
Any advise?
Daniel
