Hi guys.
I want to make a template for my custom buttons integration, but I am stuck,. I have the following:
entity: switch.door
type: custom:button-card
template: light_button
state:
- value: 'on'
styles:
card:
- transition: all 2s ease
- border-top: >
[[[ if (states['timer.timer_entrance'].state == 'idle') return
"0.5rem solid cyan"; return "0.5rem solid yellow"; ]]]
Can I make from this state: a template in raw file ?
I mean it is possible to use custom timers (like timer.timer_entrance), with template?
Thank you!
Do you want to create a template that involves multiple entities, of which one is a timer?
If so, you have two options: use a naming convention for the timer and the other related entity. You can then do a search and replace to change from the one or the other. E.g. if it’s a light such as light.my_light
and timer.my_light_timer
Alternatively, button card templates accept variables. You can specify additional entities that way.
light_with_timer:
triggers_update: all
color: var(--button-card-light-color)
styles:
name:
- color: var(--paper-item-icon-color)
label:
- color: var(--primary-background-color)
card:
- font-size: 12px
grid:
- grid-template-areas: '"t" "i" "n"'
- grid-template-rows: min-content 1fr min-content
- grid-template-columns: 1fr
custom_fields:
t:
card:
entity: "[[[ return entity.entity_id.replace('light.', 'timer.') + '_timer'; ]]]"
show_name: false
show_icon: false
show_state: true
styles:
card:
- font-size: 12px
- box-shadow: none
state:
- margin-top: -1ex
- margin-bottom: -1ex
- color: >
if (states[`${entity.entity_id}`.replace('light.', 'timer.') + '_timer'].state == 'idle')
return "var(--paper-item-icon-color)";
else
return "var(--custom-color-red)";
state:
- value: 'unavailable'
styles:
icon:
- color: var(--state-icon-unavailable-color)
tap_action:
action: toggle
haptic: light
double_tap_action:
action: call-service
haptic: medium
service: script.turn_on_light_and_timer
service_data:
light: "[[[ return entity.entity_id; ]]]"
duration: "00:03:00"
hold_action:
action: more-info
haptic: selection
- type: custom:button-card
template: light_with_timer
entity: light.living_room_lamp
Source:
Template
Use of template
Thank you very much Pieter!
I have some different timers for outside, inside, bathroom, bedroom etc, even for night or evening. So , my code is on all buttons, and I need to change somehow (if is allowed) to reflect the time for specific button.
This is because I want to keep it light for speed propose, because I use a PI.
Unfortunately I cannot adapt your example, because a timer can be used on more buttons., and I canott really use
Thank you!
To paraphrase, you have many lights, each with a matching timer you want to display on each button for that light? If so, I think we have the same idea. The code I use is lightweight, AFAIK.
well not really. one timer is for 3 buttons.
Like: timer.outside will work with switch.patio, switch.porch and switch.barbecue
so… timer + “outside” will not match let say timer + patio
EDIT: Thank you Pieter I figured out.
Do you know if is possible to combine multiple templates?
Here is the solution in case anyone want it:
in template I changed timer state with “variables.timer_c”:
state:
- value: 'on'
styles:
card:
- border-top: >
[[[ if (variables.timer_c == 'idle') return "0.5rem solid
and in dashboard i defined the button timer (timer.timer_entrance) like this:
variables:
timer_c: |
[[[ return states['timer.timer_entrance'].state ]]]
I’m with you now.
You can list templates and they will be applied in that order. You will also see this in my repo link above. For example, just put:
template:
- template_a
- template_b
So, in your case you can have a single styling template, and then one for each of the timers. If the timer is a variable, then you only need one template though, since you’ll specify the variable with the template for a button.
BTW, I think it’s cleaner / more readable to pass the entity to the variable and then do the parsing and matching all in one place.
Yes, you are right, thank you very much!
