Hidden automations after upgrade
I have a very up to date version of HAOS that I run on a mini PC:
  • Installation method Home Assistant OS
  • Core 2025.12.3
  • Supervisor 2025.12.3
  • Operating System 16.3
  • Frontend 20251203.2
I recently had to rebuild the home assistant installation. Started from reinstalling HAOS. I restored from backup and it all seemed to work.
But when I was creating a new automation I saw a few issues. I am not sure if related to the restore or due to some upgrade, before or after the rebuild.
This is what I see:
1- When I try to create a new automation using the UI, just to send a default notification when an entity state changes, the UI discards it and goes back to the initial screen.
2- I also do not see any of the automations I had previously created. I see the automations.yaml file. I also have the include in the configuration.yaml:
3- when I try to create another automation that sends a different type of notification, it goes a bit further. In this case, when I try to save the automation, I get the attached error message…
After I tried these, I also see some error messages in the home assistant logs:
2025-12-22 18:18:59.704 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved (None)
File “/usr/src/homeassistant/homeassistant/components/config/automation.py”, line 28, in hook
await hass.services.async_call(
AUTOMATION_DOMAIN, SERVICE_RELOAD, {CONF_ID: config_key}
File “/usr/src/homeassistant/homeassistant/core.py”, line 2768, in async_call
raise ServiceNotFound(domain, service) from None
homeassistant.exceptions.ServiceNotFound: Action automation.reload not found
Any ideas of how I could get Home assistant to be able to load the automations? Having just done a rebuild, I was hoping if anything, it would clear warning messages, etc I had before the rebuild…
I upgraded HA to Core 2025.12.4 and moved the automation include statement almost to the start of the config.
After a restart of HA, I can see the integrations again. And also the ones that I have been trying to create.
I read that errors in HA integrations can sometimes cause automations to go hiding…
Moving the include to the top does not affect if automations are loaded or not.
More likely you had a indentation error which was resolved when you moved that line
Ok but the file was always checking as loadable…
There are however various other cases reported over the years where HA integration errors caused the automations to not load or to not be shown in the UI.
