Hide HTTP Binary Sensor
How can i hide a HTTP Binary Sensor? I’m using this page https://home-assistant.io/components/binary_sensor.http/ to send the charging status of my smartphone, to have a dynamic icon.
I have placed it in a group and tried to hide the group but even then icon remains on top in de main view.
Any help is appreciated!
Have you tried
   customize:
        binary_sensor._______:
          hidden: true
That was the first thing I tried, has the same result.
Same problem:
  customize:
    # Add an entry for each entity that you want to overwrite.
    binary_sensor.henrik_presence:
      hidden: true
Logfile:
Konfigurationen ugyldig
Error loading /config/configuration.yaml: while scanning a simple key
in “/config/configuration.yaml”, line 21, column 5
could not find expected ‘:’
in “/config/configuration.yaml”, line 22, column 13
Last to lines is 21 and 22
looks like the http binary sensor doesnt respect the customize feature. I’m just going to use a template sensor instead.
