I’ve searched an answer but can’t find what I really would like to do!
I’m starting using views in HASSIO and I have what seems to me a pretty simple question, is there a possibility to have a default view with everything we want to use and have another view with EVERYTHING.
I simply would like to have my first tab “home” with everything me and my wife would use and another tab (in second place) where I can see all my equipments, automatically added when new ones are detected…?
you can use order: to arrange your tabs but I’m not sure if it will override the position of the default_view. Give it a try and find out. I only use Lovelace now which means starting alll over again with you GUI setup
Once you define a default_view then the original default view goes away. you can make another view that has all of your devices in it just like the original default view but you have to add everything there manually. It won’t populate that view automatically any more like the original does.
I think the closest you will get to that is to redefine the home (default) tab and then write a tab of group.all_lights, group.all_switches, group.all_devices, etc. This will display each group and you will have to click on it to see each entity within that group though.
If this is the route you are going to take, I think you will need to manually create groups for binary_sensors and sensors. Those are not automatically created.
