I'm trying to setup a not-too-old ipad as a home info display for my HA server, stuff like weather, people home, quick tv controls etc.
I have the companion app installed and the device logged in as a user of its own, set the home dash, and turned on kiosk mode in settings but the top header bar still remains - can that be removed as its looks odd and wastes screen real-estate.
I've turned off screen saver as well - is that ok with ipads?
Also, can i remote dim or sleep the app at bedtime via code in node-red??
It sounds like what you want is Fully kiosk browser on an android tablet. Those 2 with the kiosk mode HACS integration will get you what you are looking for… you can even turn the screen off at bedtime or when you leave, or brighten/dim the screen through out the day.
You can find kiosks apps in the Apple appstore too, but i find they are WAY more expensive than fully and in some cases more expensive than a cheap android tablet as well.
That seems to be good enough for now, I did try it before but didn't dig deep enough so gave up. It has managed to hide the header so thats a solution.
