Hide user from map across Home Assistant (not just the side bar)
I’ve been searching for an answer here, but not quite finding it.
Right now if you have a person entity on your UI and you click on it for more info it will show GPS coordinates and location on a map.
I’ve read about disabling map: in configuration.yaml, but that only disables the sidebar map - not the map I’m describing that shows under a person entity.
I want to disable (ideally from certain users or non-administrators) the ability to see locations of other users from any possible location in HA. I just want to use location tracking so HA knows if people are home or away.
Thoughts?
Following up here - is this possible?
any update on this?
I want to use the locations and be able to show certain people at known locations… but when they are ‘away’ I dont want non-admin users to have the possibility to see where these people are.
