Problem with connection to Strato Highdrive using SMB.
I try to add a network storage and get this result in the log file:
2025-02-23 10:54:33.057 ERROR (Dummy-1) [homeassistant.components.home assistant OS] Failed to to call /mounts - does not match regular expression [1]+ for dictionary value @ data[‘share’]. Got ‘\\smb.hidrive.strato.com\root’
required key not provided @ data[‘server’]. Got None
I do not understand why, because the username password and server name are correct. A connection using the same setting in a windows mapped network drive works fine.
The router (fritzbox) is also doing it’s job I think, becaue in Windows 11 it works.
If I replace the server name “smb.hidrive.strato.com” by it’s IP it seems that HA tries to connect, but fails also.
In the image I replaced the “disk-xxxx”, xxx is normally a number
Any Ideas ?
Best regards
Wolli
