Hi all,
I am running Home Assistant on an older Intel NUC, I started to run into serious CPU ulilization issues (the system shows a constant ~60% CPU utilization). The below screenshot actually “only” shows ~40% for the homeassistant container, but often times it is higher.
I have tried to record with py-spy through the community SSH inside the container, but everytime I try that, everything freezes and the HA system reboots after about 2-3 minutes.
You can see when the system crashed when I tried to run py-spy (every time the line is linear, not irregular).
I was successful in running the profiler and it produced:
https://drive.google.com/drive/folders/1nJCQNEeE6mgV8cbEcJ7iXoqER_LCLs7_?usp=share_link
I hope I can pinpoint the issue, I am not sure when this occurred, but I discovered the problem recently when I noticed that the frontend is behaving increasingly sluggish.
