High CPU usage after upgarding to 2021.11.1
Hi
I updated Home Assistant from 2021.10.7 to version 2021.11.1 and now Proxmox is reporting constant CPU usage of 106%. Before updating, it was at around 10%. No changes were made to the configuration. Is this a known issue?
Merijn
Installed the Glances addon after reading about that in this forum. Turned out it was Zigbee2MQTT that was burning CPU cycles because the USB-stick was not found. It was Proxmox that decided to shuffle USB portnames around after updating from 6.2 to 6.4. Sorry about the noise.
