My home-assistant instance is running slow. It is a thin PC running HAOS.
When I check CPU usage, I see it is around 20 and sometimes 40%. only about 55% of memory is used. So I would expect it to be able to be reasonably responsive.
At times, I saw file editor (File editor, Current version: 6.1.0), that runs in its own container, using 10-15% CPU. I believe I only have one browser window on it and so cannot even imagine what it could be doing.
Any ideas of what I should look into?
Some info on my instance:
Installation method Home Assistant OS Core 2026.9.1 Supervisor 2026.09.0 Operating System 18.2 Frontend 20260826.6
