Thanks I will go through that post looks very handy.
I did also notice this in my logs, wonder if related:
2025-03-20 16:36:05.135 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to open with args ('/config/custom_components/solarman/inverter_definitions/deye_hybrid.yaml',) inside the event loop by custom integration 'solarman' at custom_components/solarman/solarman.py, line 31: with open(self.path + self.lookup_file) as f: (offender: /config/custom_components/solarman/solarman.py, line 31: with open(self.path + self.lookup_file) as f:), please create a bug report at https://github.com/StephanJoubert/home_assistant_solarman/issues
For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#open
File "<frozen runpy>", line 198, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code
File "/usr/src/homeassistant/homeassistant/__main__.py", line 227, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 213, in main
exit_code = runner.run(runtime_conf)
File "/usr/src/homeassistant/homeassistant/runner.py", line 154, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 712, in run_until_complete
self.run_forever()
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 683, in run_forever
self._run_once()
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 2040, in _run_once
handle._run()
File "/usr/local/lib/python3.13/asyncio/events.py", line 89, in _run
self._context.run(self._callback, *self._args)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 898, in async_setup_locked
await self.async_setup(hass, integration=integration)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 664, in async_setup
await self.__async_setup_with_context(hass, integration)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 753, in __async_setup_with_context
result = await component.async_setup_entry(hass, self)
File "/config/custom_components/solarman/__init__.py", line 18, in async_setup_entry
await hass.config_entries.async_forward_entry_setups(entry, PLATFORMS)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 2573, in async_forward_entry_setups
await self._async_forward_entry_setups_locked(entry, platforms)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 2584, in _async_forward_entry_setups_locked
await asyncio.gather(
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 2586, in <genexpr>
create_eager_task(
File "/usr/src/homeassistant/homeassistant/util/async_.py", line 45, in create_eager_task
return Task(coro, loop=loop, name=name, eager_start=True)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 2665, in _async_forward_entry_setup
await entry.async_setup(self.hass, integration=integration)
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 96, in async_setup_entry
return await hass.data[DATA_COMPONENT].async_setup_entry(entry)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 193, in async_setup_entry
return await self._platforms[key].async_setup_entry(config_entry)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 349, in async_setup_entry
return await self._async_setup_platform(async_create_setup_awaitable)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 379, in _async_setup_platform
awaitable = create_eager_task(awaitable, loop=hass.loop)
File "/config/custom_components/solarman/sensor.py", line 89, in async_setup_entry
_do_setup_platform(hass, entry.options, async_add_entities)
File "/config/custom_components/solarman/sensor.py", line 54, in _do_setup_platform
inverter = Inverter(path, inverter_sn, inverter_host, inverter_port, inverter_mb_slaveid, lookup_file)
File "/config/custom_components/solarman/solarman.py", line 31, in __init__
