High CPU usage with latest OS - solved
If you are noticing a problem with high CPU usage, this information may help. I am a new user to Home Assistant. I have a Home Assistant Green and I have been slowly adding devices and automations. My CPU usage was typically averaging 2%. All of a sudden, I noticed the CPU usage go up to 26%.
After some debugging and googling the issue, I realized that it was an HA OS upgrade issue. I was always updating to the latest version. I was using the latest OS version (I think 15.2x?). I downgraded to the HA OS 14.2 and my CPU usage went back down to 2%. Problem solved
From the terminal, I used the following command and it fixed the problem:
ha os update –version “14.2”
Eh, not a fix… And some advice for a new user.
(first I’ll begin with I’m an ex-server performance engineer)
Let’s start with… Up to 26% by is not an issue by itself.
Up to x percent and NOT running, throwing errors IS an issue. In fact I love to see all my gear running at 80% all the time (I’m getting my $ worth)
But just running at a higher percentage should not be itself a reason for rollback. Sometimes there may be a legit reason. (dB maintenance running for a few hours or days in some rare cases after installation) you should let it settle for a fews days if the machine is not erroring.
If it continues the use the information in the cookbook (search here for HA cookbook it will be one of the first 5 hits) to investigate the
So. Hi Cpu for unknown reason is only a workaround for an issue that may not exist. We’re you able to get any logs indicating what was burning Cpu? Any other data?
Reason I say. Is basically now you’re sitting waiting for a time bomb because you rolled back… If you don’t know why the Cpu ‘spiked’ when 15.x.x releases, will you just stay?
I get that you did some research and decided rollback was best for you. But with no indication of why it’s just a random report that nobody can investigate to make better. So any additional info as to what it was or?
Hi, Bob, welcome to the forum!
Please take the time to mark @NathanCu his post as the solution, you do that by selecting the three dots under the post:
Then select the check box:
By doing so:
  • this thread can be useful to other users as well (this thread comes up as solution when starting a thread which is similar to yours).
  • this prevents that someone else steps in trying to help
Thanks for giving back to the community! :+1:
