see first post where you can find my addon and docs
Hi @pergola.fabio does the “frigate card with go2rtc” solution work for you in the android companion app locally (when in the same network), showing microphone?
The app seem to be unable to work with the self signed https certificate, and the trusted authorities like let’s encrypt issue certificates for the internet addresses only, not my local ip/name… What certificate does your nginx serve and do you use the phone app?
It should normally, but the frigate card can only work on https with valid ssl, don’t think there is an relationship how you run companion app
Hello! Is there a way to simulate pressing the doorbell through homeassistant?
not that i know off
Hi Fabio,
thanks for your great support and for this perfect integration.
In the past, i used my Hikvision 8003 Doorstation only for testing purposes. But not i want to switch from BJ to Hikvision with HA.
In this step, i got a problem, what some other people in the past already had.
The “answer” and “hangup” does not work in my setup. I am sending the commands as described below to my indoor station DS-KH6320WTE. As Response, i always get the 29, “Device operation failed”. The Reject, i can sent and its OK. But for “answer” and “hangup” i always get Statuscode 4, Invalid Operation.
I send the “answer” and “hangup” when an active call is started and my Indoor Station is ringing.
Do you know, if i have to configure something else? Is there something missing in my setup?
TLS or SSL is not active on my 8003 and 6320 Devices. Is it necessary. Could not find a way, to configure it in iVMS.
Thanks for your help
Best regards
For an unknown reason, answer+hangup only works when indoor device is connected to hikconnect, are you using hikconnect?
Hey so fast reply, wow.
No, i am not using hikconnect.
Do i need full activation at hikvisions backend to get it working?
i will try it and give an answer.
yeah, it needs to be connected, not sure why, didnt find an alternative
or you can use “reject” instead
Top, thanks very much.
After registering at HIK Connect, its now working as expected.
You are the best
Greetings!
Tell me, please!
How can I get the ID key that was used to open the door on DS-KV6113-WPE 1(C)?
it should be visible as an attribute on the door switch entity;, its called “control_source” its not the ID of the card itself, but its an unique value
Thank you very much!
Hi all,
I am wondering if the Hikvision DS-KB8113-IME1(B) is working or not with all of the events. If have been working through this thread and it stil isn’t clear to me. I read it should be working but I have also read in this thread it wasn’t.
I am especially anxious if the ringing event is being published. But, if possible, I am also interested in which events you actually receive.
Could someone please confirm it is working (or isn’t but that is not what I am hoping for ). If it is working, would you mind sharing your setup?
Thx. Best regards.
Hi @pergola.fabio,
It’s been a long time. I’ve not paid much attention to the doorbell thing for a while as it’s been working but I recently changed to using the Frigate card (now called the Advanced Camera Card) - Frigate has been updated too.
Everything is working, 2 way audio, answer, hangup (although for the Indoor Station needs to be connected to Hik-Connect to work).
The only thing that has stopped working is the 2 way audio AFTER the answer and hangup. If you leave it for 5-10 mins the two way audio works again if you don’t ring the doorbell.
My card config is below.
My answer call button should clear the audio channel with PUT /ISAPI/System/TwoWayAudio/channels/1/close then answer and hangup the Indoor station - then I would expect the microphone and speaker to be free on the outdoor station but this isn’t working any more. Any ideas and sorry if the answer is in the thread - but I didn’t see anything relating to this for months.
type: custom:advanced-camera-card
cameras:
- camera_entity: camera.millersdoorstation
live_provider: go2rtc
menu:
style: overlay
position: bottom
buttons:
microphone:
enabled: true
type: toggle
screenshot:
enabled: false
download:
enabled: false
fullscreen:
enabled: false
snapshots:
enabled: false
timeline:
enabled: false
media_player:
enabled: false
clips:
enabled: false
live:
enabled: false
cameras:
enabled: false
camera_ui:
enabled: false
iris:
enabled: false
live:
microphone:
always_connected: false
disconnect_seconds: 0
auto_mute: []
auto_unmute: []
controls:
builtin: true
elements:
- type: custom:advanced-camera-card-menu-icon
icon: mdi:volume-high
tap_action:
- action: custom:advanced-camera-card-action
advanced_camera_card_action: unmute
icon: mdi:volume-off
tap_action:
advanced_camera_card_action: mute
icon: mdi:phone
tap_action:
- action: perform-action
entity_id: text.indoor_station_isapi_request
value: PUT /ISAPI/System/TwoWayAudio/channels/1/close
perform_action: text.set_value
entity_id: button.indoor_station_answer_call
perform_action: button.press
duration:
ms: 500
advanced_camera_card_action: sleep
entity_id: button.indoor_station_hangup_call
duration:
ms: 500
advanced_camera_card_action: microphone_unmute
icon: mdi:phone-hangup
tap_action:
advanced_camera_card_action: microphone_mute
view:
default: live
I don’t use it myself, but I tested it, it should work, I have an updated guide on my github
Hi @pergola.fabio. According to your guide I need to be clearing the channel with the outdoor station - not the indoor. However I don’t have the
text.ds_kd8003_isapi_request
Entity - do I need to re-install the add-on to get it. I have the same outdoor unit as you.
Ok , seems my guide is wrong, you need to send it to indoor station , my bad…
If you don’t seen the entity, it’s maybe disabled , you can enable it
Hi! I am still playting with the AddOn.
I have installed a contact sensor in my main door, the idea is when I open the door , doorbell shuts but I dont seem to achieve it. I open the door but I still hear the ringing
Here I share the automation maybe I am doing something wrong.
First I send the reject action to the one indoor panel, but since it was not working I sent it to the other indoor and the outdoor unit
alias: COLGAR TELEFONO CUANDO SE ABRE LA PUERTA
description: ""
triggers:
- entity_id:
- binary_sensor.sensor_puerta_principal_contact
to: "on"
trigger: state
conditions:
- condition: template
value_template: >-
{{ (as_timestamp(now()) -
as_timestamp(states.sensor.timbre_call_state.last_changed)) < 30 }}
actions:
- action: hassio.addon_stdin
addon: aff2db71_hikvision_doorbell
input: reject panel_cocina
input: reject panel_pa
input: reject timbre
mode: single
Send it to your primary indoor, that should be enough, no need to send it to all devices…
