HINK-E075A07-A0 7.5inch 880x528 e-ink display with esphome - blank display
Hi there
I just got one of these https://www.aliexpress.com/item/1005008096259306.html
( HINK-E075A07-A0 7.5inch 24Pin 880x528 e-Paper E-ink raw Display Red Black White )
Along with a https://www.aliexpress.com/item/1005009827197743.html ( Waveshare e-Paper ESP32 Driver Board Rev 3 )
Hooked it all up, and configured the GPIOs according to the image on the waveshare site
However I am getting zero reaction out of the e-ink display.
This e-ink display is 7.5" however the resolution is 880x528 pixels - the waveshare site for the driver board doesn’t list this res. With some google-fu I found I can use “generic SPI” to drive this display:
esphome:
esp32:
  board: esp32dev
  framework:
    type: esp-idf
logger:
  level: VERBOSE
api:
  encryption:
    key: "redacted"
ota:
  - platform: esphome
    password: "redacted"
wifi:
  ssid: !secret wifi_ssid
captive_portal:
font:
  - file: "fonts/menlo.ttf"
spi:
  clk_pin: GPIO13
  mosi_pin: GPIO14
display:
  - platform: epaper_spi
    model: SSD1677        # Via https://esphome.io/components/display/epaper_spi/
    cs_pin: GPIO15
    dc_pin: GPIO27
    reset_pin: GPIO26
    busy_pin: { number: GPIO25, inverted: False, mode: { input: True, pulldown: True } }
    dimensions:
      width: 880
      height: 528
    full_update_every: 1
    update_interval: 10s
    lambda: |-
      it.fill(Color::WHITE);
      it.print(0, 0, id(font_menlo), Color::BLACK, "HELLO WORLD!");
But I got no reaction from the display; so and get this in the logs:
[I][app:194]: ESPHome version 2025.12.2 compiled on Dec 29 2025, 17:24:09
-- irrelevant stuff removed --
[C][spi:067]: SPI bus:
[C][spi:068]:   CLK Pin: GPIO13
[C][spi:069]:   SDI Pin:
[C][spi:070]:   SDO Pin: GPIO14
[C][spi:075]:   Using HW SPI: SPI2_HOST
[C][epaper_spi:329]: E-Paper SPI
[C][epaper_spi:329]:   Rotations: 0 °
[C][epaper_spi:329]:   Dimensions: 880px x 528px
[C][epaper_spi:330]:   Model: SSD1677
[C][epaper_spi:331]:   Reset Pin: GPIO26
[C][epaper_spi:332]:   DC Pin: GPIO27
[C][epaper_spi:333]:   Busy Pin: GPIO25
[C][epaper_spi:334]:   CS Pin: GPIO15
[C][epaper_spi:399]:   Update Interval: 10.0s
[C][epaper_spi:336]:   SPI Data Rate: 20MHz
[C][epaper_spi:336]:   Full update every: 1
[C][epaper_spi:336]:   Swap X/Y: NO
[C][epaper_spi:336]:   Mirror X: NO
[C][epaper_spi:336]:   Mirror Y: NO
[V][epaper_spi:226]: Exit state IDLE
[V][epaper_spi:234]: Enter state UPDATE, delay 0, wait_for_idle=FALSE
[V][epaper_spi:165]: Process state entered in state UPDATE
[V][epaper_spi:226]: Exit state UPDATE
[V][epaper_spi:234]: Enter state RESET, delay 0, wait_for_idle=FALSE
[V][epaper_spi:165]: Process state entered in state RESET
[V][epaper_spi:226]: Exit state RESET
[V][epaper_spi:234]: Enter state RESET_END, delay 10, wait_for_idle=FALSE
[V][epaper_spi:165]: Process state entered in state RESET_END
[V][epaper_spi:226]: Exit state RESET_END
[V][epaper_spi:234]: Enter state INITIALISE, delay 0, wait_for_idle=TRUE
[V][epaper_spi:141]: Screen was busy for 4 ms
[V][epaper_spi:165]: Process state entered in state INITIALISE
[V][epaper_spi:071]: Command: 0x18, Length: 1, Data: 80
[V][epaper_spi:071]: Command: 0x0C, Length: 5, Data: AE.C7.C3.C0.80
[V][epaper_spi:071]: Command: 0x01, Length: 3, Data: 6F.03.02
[V][epaper_spi:071]: Command: 0x3C, Length: 1, Data: 01
[V][epaper_spi:071]: Command: 0x11, Length: 1, Data: 03
[V][epaper_spi:226]: Exit state INITIALISE
[V][epaper_spi:234]: Enter state TRANSFER_DATA, delay 0, wait_for_idle=TRUE
[V][epaper_spi:141]: Screen was busy for 5 ms
[V][epaper_spi:165]: Process state entered in state TRANSFER_DATA
[V][epaper_spi:071]: Command: 0x4E, Length: 2, Data: 00.00
[V][epaper_spi:071]: Command: 0x44, Length: 4, Data: 00.00.6F.03
[V][epaper_spi:071]: Command: 0x4F, Length: 2, Data: 00.00
[V][epaper_spi:071]: Command: 0x45, Length: 4, Data: 00.00.0F.02
[V][epaper_spi.ssd1677:061]: Writing bytes at line 0 at 15249ms
[V][epaper_spi.ssd1677:061]: Writing bytes at line 1 at 15263ms
[V][epaper_spi.ssd1677:061]: Writing bytes at line 38 at 15281ms
[V][epaper_spi.ssd1677:061]: Writing bytes at line 115 at 15295ms
[V][epaper_spi.ssd1677:061]: Writing bytes at line 165 at 15313ms
[V][epaper_spi.ssd1677:061]: Writing bytes at line 238 at 15327ms
[V][epaper_spi.ssd1677:061]: Writing bytes at line 301 at 15345ms
[V][epaper_spi.ssd1677:061]: Writing bytes at line 375 at 15359ms
[V][epaper_spi.ssd1677:061]: Writing bytes at line 452 at 15377ms
[V][epaper_spi.ssd1677:061]: Writing bytes at line 521 at 15390ms
[V][epaper_spi:226]: Exit state TRANSFER_DATA
[V][epaper_spi:234]: Enter state POWER_ON, delay 0, wait_for_idle=TRUE
[V][epaper_spi:141]: Screen was busy for 9 ms
[V][epaper_spi:165]: Process state entered in state POWER_ON
[V][epaper_spi:226]: Exit state POWER_ON
[V][epaper_spi:234]: Enter state REFRESH_SCREEN, delay 0, wait_for_idle=TRUE
[V][epaper_spi:141]: Screen was busy for 7 ms
[V][epaper_spi:165]: Process state entered in state REFRESH_SCREEN
[V][epaper_spi.ssd1677:011]: Refresh screen
[V][epaper_spi:226]: Exit state REFRESH_SCREEN
[V][epaper_spi:234]: Enter state POWER_OFF, delay 0, wait_for_idle=TRUE
[V][epaper_spi:165]: Process state entered in state POWER_OFF
[V][epaper_spi:226]: Exit state POWER_OFF
[V][epaper_spi:234]: Enter state DEEP_SLEEP, delay 0, wait_for_idle=TRUE
[V][epaper_spi:165]: Process state entered in state DEEP_SLEEP
[V][epaper_spi.ssd1677:018]: Deep sleep
[V][epaper_spi:226]: Exit state DEEP_SLEEP
[V][epaper_spi:234]: Enter state IDLE, delay 0, wait_for_idle=FALSE
[D][epaper_spi:220]: Display update took 362 ms
I am assuming the esp32 is able to transmit the display data to the display (Or else I would expect there would be some errors?) But I have no reaction from the display at all (it’s totally “white”, i.e. how it looked when it was shipped to me).
I’ve searched for people using this specific display, but I’ve come up short - however, I assumed this is like many other things HomeAssistant - close enough that it’ll work but this time, that appears to not be the case.
Any guidance on how to get this going would be appreciated!
Did you try the Waveshare demo code to verify your devices are working?
I found the issue… I had a loose connection. Its working now. Here is the code I’m using:
font:
  - file: "gfonts://Open Sans@700"
  - file: "gfonts://Montserrat@800"
  - file: "gfonts://Bitter@900"
spi:
  clk_pin: GPIO13
  mosi_pin: GPIO14
display:
  - platform: waveshare_epaper
    update_interval: 600s
    cs_pin: GPIO15
    dc_pin: GPIO27
    busy_pin: GPIO25
    reset_pin: GPIO26
    model: 7.50in-hd-b
    lambda: |-
      it.print(10, 20, id(font_menlo), "The quick brown fox jumps over the lazy dog");
      it.print(10, 80, id(font_bitter), "The quick brown fox jumps over the lazy dog");
      it.print(10, 140, id(font_montserrat), "The quick brown fox jumps over the lazy dog");
      it.print(10, 200, id(font_os_bold), "The quick brown fox jumps over the lazy dog");
Only thing is I haven’t figured out how to draw in red colour :wink:
Docs have example for that
lambda: |-
  const auto BLACK   = Color(0,   0,   0,   0);
  const auto RED     = Color(255, 0,   0,   0);
  it.print(100, 100, id(font1), RED, "Hello World in red!");
Yes I tried that:
font:
spi:
  clk_pin: GPIO13
  mosi_pin: GPIO14
display:
    cs_pin: GPIO15
    dc_pin: GPIO27
    busy_pin: GPIO25
    reset_pin: GPIO26
    model: 7.50in-hd-b
    lambda: |-
      it.print(10, 260, id(font_menlo), RED, "Hello World in red!");
Unfortunately it comes up in B/W:
try to flip the dip switch a/b and repower the board.
were you able to get it working? I have the same display and Red does not work. WaveShare Demo code does work and show both black and red.
Sorry @jlboygenius I didn’t see your reply until just now. No, I didn’t get the RED colour working. I Just use it as display to show forecast/outside/inside temps, so black and white was sufficient for that.
