Hisense WD5i8014-FVW001 washer dryer using ConnectLife in Home Assistant
I’m integrating a Hisense WD5i8014-FVW001 washer dryer using ConnectLife in Home Assistant.
I see several energy-related sensors (such as “Daily energy consumption”, “Estimated energy consumption”, “Electricit consumption”), but values seem to be always zero or constant.
Does anyone with ConnectLife or a similar Hisense washer dryer get realistic values in these sensors?
Are the energy readings calculated by the cloud/app or are there actual device readings?
Is it possible to validate (or “write”) these values in Home Assistant, or do I need to use a smart plug with energy metering for the Energy Dashboard integration?
Thanks to anyone with experience on this model/integration!
Same issue for me! Shame :frowning:
