I have a problem with my home assistant installation ver 0.26.3 on QNAP TS-210 (arm based linux).
When I try to show history neither logbook, only see loading gif.
The home-assistant.db does not create. If i configure recorder with mysql (db_url), the tables are not created on my mysql server.
In the logs are not errors
Any ideas?
Mi conf is this:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: !secret home_lat
longitude: !secret home_long
# Impacts weather/sunrise data
elevation: !secret home_elev
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Europe/Madrid
# customization
customize: !include customize.yaml
zone:
latitude: !secret school_lat
longitude: !secret school_long
icon: mdi:school
zone 2:
latitude: !secret work_d_lat
longitude: !secret work_d_long
icon: mdi:worker
# Show links to resources in log and frontend
#introduction:
# Enables the frontend
frontend:
http:
# Uncomment this to add a password (recommended!)
api_password: !secret front_end_pw
ssl_certificate: ssl/SSLcertificate.crt
ssl_key: ssl/SSLprivatekey.key
# Checks for available updates
updater:
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
recorder:
purge_days: 14
db_url: !secret db_url
# Enables support for tracking state changes over time.
history:
# View all events in a logbook
logbook:
# Track the sun
sun:
# Weather Prediction
platform: yr
monitored_conditions:
- temperature
- symbol
- precipitation
- windSpeed
- humidity
media_player:
platform: pioneer
host: !secret pioneer_host
mqtt:
broker: !secret mqtt_server
port: !secret mqtt_port
username: !secret mqtt_user
password: !secret mqtt_pw
device_tracker:
- platform: ddwrt
host: !secret ddwrt_host
username: !secret ddwrt_username
password: !secret ddwrt_pw
# If new discovered devices are tracked by default (default: yes)
track_new_devices: yes
# Seconds between each scan for new devices (default: 12)
interval_seconds: 30
# Seconds to wait till marking someone as not home after not being seen
# (default: 180)
consider_home: 180
- platform: owntracks
max_gps_accuracy: 200
switch:
platform: transmission
host: !secret transmission_host
port: 9091
username: !secret transmission_user
password: !secret transmission_pw
group: !include group.yaml
automation: !include automation.yaml
