In the History Graph card, you can choose “Hours to show”.You can’t enter a (decimal) number less than 1 in the field. Is there a way to have the card show (for example) 30min? Or 10s?
EDIT: As usual, right after posting, I figured out you CAN enter a decimal value less than 1.
The field becomes red, as if it’s an unsupported entry. But you can still save it and it works.
Is there a reason why the field turns red with a value less than 1?
