I am running home assistant in docker on a pi 3B+ with the homeassistant/raspberrypi3-homeassistant image.
when i open the history tab or the history of a component the following situation occurs
the tab becomes unresponsive and has to be closed (refreshing doesnt work)
the same thing happens in chrome and other browsers.
only devices with multiple datastreams load their history but this also looks wrong:
(look at the Y axis)
When is run a new container with the default configuration.yaml this also occurs.
what could be causing this ?
