History Markers/Notes
I’ve looked all over so hopefully I’m not missing this feature somewhere. I would like to see an ability to add a “marker” to the history that can be displayed along with any of the other history views.
For example, I have an ESPHome in my RV monitoring temperature and humidity. I placed a dehumidifier out there and would like to be able to click a button to add a note to the history marking when I turned the dehumidifier on. That way I can better see how things have changed since that moment.
So something like this?
Screenshot 2021-11-27 at 17-10-11 Administration - Home Assistant
Rather than you manually placing a marker, you graph when the dehumidifier is on, on the same graph as your humidity sensor.
This requires a custom card that supports graphing binary sensors and sensors on the same graph. The core History Graph card can’t do this.
Apexcharts can.
So can the min-graph-card.
This does look like a solution to accomplish what my example. In my case the dehumidifier is “dumb” and not connected to HA, but I could accomplish this with a virtual switch.
Personally I think it would still be nice to have an easy way to add an arbitrary, timestamped note to the history table.
Thank you
Did you ever find a good solution for this? I actually want to do something similar that couldn’t be solved with a simple on/off toggle.
I’m tracking noise levels with a sound level meter and want to annotate a graph with what kinds of things were happening at the time – traffic, gardeners, mainteance work, etc. I can keep the list of events elsewhere if necessary, but getting it into a graph in HA would be really nice.
I’m just stumbling onto this feature request as I have the same need. FWIW, I’m going to try to implement it using a text sensor and Apex charts and some way to push an arbitrary value to the text sensor. Hopefully then all I need to do is display the history of the text sensor on the chart.
