History module
ich have a Problem with the history module, i can’t see anything on the history page. I don’t think it is a problem with the recording, because I can see the entry in the Logbook.
Because of the mentioning in other threads I changed to the MariaDB Add-on for the recording, but the problem unfortunately still exists.
I would be happy if anyone can help me with this problem or can point me in the right direction so that i can find my problem.
here are the entries regarding history and recorder from my configuration.yaml
# Enables support for tracking state changes over time
history:
  include:
    domains:
      - sensor
      - switch
  exclude:
    entities:
      - sensor.no_updates
    domains:
      - proximity
recorder:
  purge_interval: 2
  purge_keep_days: 12
  db_url: mysql://hass:passwordl@core-mariadb/homeassistant
thanks
Fabian
I would try with no includes or excludes and see what you get.
history:
recorder:
  purge_interval: 2
  purge_keep_days: 12
Thanks for your reply.
I erased the includes and excludes but unfortunately the situation didn’t change.
I tried to dig a little deeper into this, and I found out that it work in Chrome but not in Safari, both on macOS.
A first difference is, that with safari it shows me a error that https://myurl.duckdns.org:8123/static/webcomponents-lite.js.map is not found (404 http error)
I will analyse this further in the next days to find this browser depending problem.
If anyone else with this problem finds this thread, I have found a solution in the github issue https://github.com/home-assistant/home-assistant/issues/11234:
frontend:
  javascript_version: es5
and now it works like I expected it.
