Mokin88
(Mokin88)
1
Hello, noob starting ha-project and got problem which googling didn’t help
Added to configuration.yaml next part
- platform: history_stats
entity_id: switch.lvvshelly
state: "on"
type: time
start: "{{ today_at() }}"
end: "{{ now() }}"
Switch.lvvshelly is shelly em3 switch. I don’t see that appearing in developer tools->states or in entities
Same problem with shelly s plug+, everything copy-pastes from examples and little modifications (name mostly), but nothing happens.
Need to create automation that if switch hasn’t been on for 24h (or 23.59h), it would send notification
tom_l
2
Where exactly did you put that in your configuration.yaml file?
And is it indented like you have shown above?
Because that is not correct.
Mokin88
(Mokin88)
3
Looks like this
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
sensors:
*many rows of code between*
# Sensor for Riemann sum of energy consumption (W -> Wh)
- platform: integration
source: sensor.power_consumption
unit_prefix: k
round: 2
method: left
# Example configuration.yaml entry
state: "on"
type: time
end: "{{ now() }}"
tom_l
4
You don’t appear to have a sensor:
integration.
sensor: # add this if it is not already in your configuration.yaml file
unit_prefix: k
state: "on"
type: time
end: "{{ now() }}"
Mokin88
(Mokin88)
5
Was wrong, it did appear. Big thanks, so easy thing and so easy to get wrong
