Hive heating with door window contacts
Hello Everyone.
This would be my first time with home assistant. I have a hive heating system, with smart TRV’s and door window contacts.
So questions.
  1. Hive does not poll door/window contacts, can this be done wth home assistant?
  2. How would I set up multple door/window contacts to turn off one or more TRV’s.
  3. Can any of this be setup without writing code?
TIA
Adrian
Yes
You would need to set-up automations / scripts
You might be able to do this using the Automation UI or through Node-Red. However, it would be easiest with code and potentially using some of the Advanced Heating Control scripts that have been posted in other threads here.
Hi
I am really struggling to find what I need. do you have any specific posts that would help. I only have heating, and need to be able to turn on schedule when doors/windows are closed, and turn off when doors/windows are open. I have smart TRV’s that need to be controlled by several door/window contacts.
Any help would be appreciated.
Adrian
Would this work?
