Hive - Help!
Hi All,
I’m struggling with getting hive integrated.
I tried getting help in another post but it went dead.
I run through the two factor authentication and it still notes it can’t Auth
Any ideas?
By hive, you are referring to hive mqtt? I don’t use it but have you tried with mqtt explorer to log into the server, does that work?
Thanks for your reply.
No I mean Hive home heating.
Are you on HA 2022.7.6 +
If so, remove the integration, restart and re-add the integration.
Also, are you using the custom component or the official one ?
I’ve tried both HACS and official. Still no joy.
Just now updating to 2022.8.0
Well updating to the latest os worked.
Providing I don’t loose access to the app like I used to that’s it.
