Hive integration now has errors
My previously working hive integration now has errors,
File “/usr/src/homeassistant/homeassistant/components/hive/config_flow.py”, line 93, in async_step_2fa
return await self.async_setup_hive_entry()
File “/usr/src/homeassistant/homeassistant/components/hive/config_flow.py”, line 108, in async_setup_hive_entry
await self.hive_auth.device_registration(“Home Assistant”)
File “/usr/local/lib/python3.9/site-packages/apyhiveapi/api/hive_auth_async.py”, line 460, in device_registration
File “/usr/local/lib/python3.9/site-packages/apyhiveapi/api/hive_auth_async.py”, line 480, in confirm_device
2022-06-12 13:56:47 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry “email address” for hive
File “/usr/src/homeassistant/homeassistant/components/hive/init.py”, line 89, in async_setup_entry
devices = await hive.session.startSession(hive_config)
File “/usr/local/lib/python3.9/site-packages/apyhiveapi/session.py”, line 493, in startSession
File “/usr/local/lib/python3.9/site-packages/apyhiveapi/session.py”, line 416, in getDevices
await self.hiveRefreshTokens()
File “/usr/local/lib/python3.9/site-packages/apyhiveapi/session.py”, line 303, in hiveRefreshTokens
File “/usr/local/lib/python3.9/site-packages/apyhiveapi/api/hive_auth_async.py”, line 537, in refreshToken
Home Assistant Core 2022.6.5
Home Assistant Supervisor 2022.05.3
Home Assistant OS 8.1
Have a search on here, there’s a few threads about it, there’s some issues recently
I deleted all references to the integration, changed the email address on the Hive app for another email, with TFA, added the integration with the new email log on, all now works!
I had this issue, I just turned on 2FA within the Hive app (can’t do it on the website) and then added it again, all working.
Same here. Seems counter-intuitive, but this is the solution.
Thank you for sharing this. This is really helpful! Now mine is set up too. :smiley:
