HLK-LD2410 detects IR signals as presence
hi
hlk-2410 detect IR signals as presence details are as under
i hv buy hlk-ld2410b and hlk-ld2410c for my home use… i am using it directly with esphome for turning on and off my lights and AC using IR transmitter
i hv set an automation turn on lights and ac if presence detected and turn off if not
whenever IR send signal to turn off my ac ld2410 also detect it as presence and turn lights and ac and it goes into loop turn ac and lights on and off again and again
basically ld2410 detects any IR signal as presence for few second any idea how to solve it
Have you tried adjusting the threshold?
yeah but that effects on efficacy
i set timeout 1s but even then it shows presence for 5-10 seconds when IR send signal
So I think you will need to move the ld2410 to another position.
ok one more thing if i install 10 hlk-ld2410 to different esp32 connecting to home assistant for automation… should i change the name of all entities of every esp32 like g0 move threshold, this will stay same for all devies or need to unique name for all devices like esp1 g0 move threshold, esp3 g0 move threshold.
cus after installing ld2410 my devices goes unavailable again and again, i hv checked voltages are stable, good wifi signals dont understand why it is
