HLKRadarTool : unable to create zone
Screenrecording https://youtu.be/WObkxQwXlh0
I’m unable to create a zone whatever sensor I use, I got it to work a while ago with a LD2450, but trying new one, but I can’t set a zone
this has nothing to do with ESPHome, HLKRadarTool connects to LD2450 over Bloetooth…
i’d just try to reset the sensor and try again
Only the LD2450 supports zones.
I would try doing a factory restore and trying it again.
Also depending on which YAML config you use for ESPHome for the LD2450, will determine how you define the zones.
A number of the YAML configs available have the zones set in the config and HA and not via the HLKRadarTool app.
Yes that exactly what I thought, I’m trying using another code thanks
