Hmip does not switch nuki
Hello dear community,
I’m new to the home assistant story and I need your help right away.
I have created an automation system that, when I switch on my hmip alarm system, should also lock my nuki front door lock at the same time.
However, the automation does not work as intended.
If I lock the nuki, for example using a lamp, the lock works perfectly.
The nuki lock works perfectly in all, but not with the automation of the arming of the alarm system.
Who maybe has a solution?
