Home Assistant 2021.10.5 crashing
I am running Home Assistant 2021.0.5 on a RPI4 4GB with a 500GB SSD (no SC Card). Lately it has crashed several times and I can’t figure out what is causing it. Below is the Core log I was able to grab this morning. It would appear that the system crashed just after midnight.
I see lots of LIFX related errors (I wish I knew how to get rid of those as the clutter everything, but bulbs appear to work just fine).
Just before the gap in the logs there is an error I can’t decipher.
I am about to upgrade to 2021.10.6 but I don’t see anything in the release notes that may be related to my issue. Anyone see what the issue is?
  File "/usr/local/lib/python3.9/asyncio/events.py", line 80, in _run
    self._context.run(self._callback, *self._args)
  File "/usr/local/lib/python3.9/asyncio/selector_events.py", line 1029, in _read_ready
    self._protocol.datagram_received(data, addr)
  File "/usr/local/lib/python3.9/site-packages/aiolifx/aiolifx.py", line 180, in datagram_received
    getattr(self, setmethod)(response)
  File "/usr/local/lib/python3.9/site-packages/aiolifx/aiolifx.py", line 1084, in resp_set_multizonemultizone
    self.color_zones[i] = resp.color[i - resp.index]
IndexError: list assignment index out of range
2021-10-17 12:36:55 ERROR (MainThread) [homeassistant] Error doing job: Exception in callback _SelectorDatagramTransport._read_ready()
2021-10-17 12:36:56 ERROR (MainThread) [homeassistant] Error doing job: Exception in callback _SelectorDatagramTransport._read_ready()
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] done.
[services.d] starting services
[services.d] done.
CRASHED HERE ?
2021-10-18 07:59:02 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-10-18 07:59:02 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration nodered which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-10-18 07:59:02 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration favicon which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-10-18 07:59:02 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration auto_backup which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-10-18 07:59:02 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration waste_collection_schedule which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-10-18 07:59:02 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration mail_and_packages which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-10-18 07:59:02 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration victorsmartkill which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-10-18 07:59:02 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration keymaster which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-10-18 07:59:02 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-10-18 07:59:02 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration unifiprotect which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-10-18 07:59:02 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration spotcast which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-10-18 07:59:04 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=121 from 2021-10-18 01:51:56)
2021-10-18 07:59:24 WARNING (MainThread) [homeassistant.setup] Setup of input_datetime is taking over 10 seconds.
2021-10-18 07:59:24 WARNING (MainThread) [homeassistant.setup] Setup of timer is taking over 10 seconds.
2021-10-18 07:59:27 WARNING (MainThread) [homeassistant.setup] Setup of input_text is taking over 10 seconds.
2021-10-18 07:59:27 WARNING (MainThread) [homeassistant.setup] Setup of input_boolean is taking over 10 seconds.
2021-10-18 07:59:30 WARNING (MainThread) [homeassistant.setup] Setup of input_number is taking over 10 seconds.
2021-10-18 07:59:33 WARNING (MainThread) [homeassistant.helpers.template] Template warning: 'timestamp_custom' got invalid input '00:00' when compiling template '{{ '00:00' | timestamp_custom('%H:%M') }}' but no default was specified. Currently 'timestamp_custom' will return '00:00', however this template will fail to render in Home Assistant core 2021.12
2021-10-18 07:59:37 WARNING (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for esp-wroom-32 (192.168.3.191): Error connecting to ('192.168.3.191', 6053): [Errno 113] Connect call failed ('192.168.3.191', 6053)
2021-10-18 07:59:38 ERROR (MainThread) [homeassistant.components.zwave_js] Discovery for value Value(value_id='76-50-0-value-1') on device 'Dehumidifier' (Node(node_id=76)) will be skipped: Value Value(value_id='76-50-0-value-1') has unknown data in the following location: metadata.cc_specific.meterType. A reinterview of node Node(node_id=76) may correct this issue, but if it doesn't, please report this issue as it may be caused by either an upstream issue with the driver or missing support for this data in the library
2021-10-18 07:59:59 ERROR (stream_worker) [libav.h264] cabac decode of qscale diff failed at 163 91
2021-10-18 07:59:59 ERROR (stream_worker) [libav.h264] error while decoding MB 163 91, bytestream 31033
2021-10-18 08:00:18 WARNING (MainThread) [homeassistant.helpers.template] Template warning: 'round' got invalid input 'None' when rendering template '{{ state_attr('binary_sensor.google_dns_ping', 'round_trip_time_avg')|round(2) }}' but no default was specified. Currently 'round' will return 'None', however this template will fail to render in Home Assistant core 2021.12
2021-10-18 08:00:28 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x49D4:1:0x0b04]: async_initialize: all attempts have failed: [DeliveryError('[0x49d4:1:0x0b04]: Message send failure'), DeliveryError('[0x49d4:1:0x0b04]: Message send failure'), DeliveryError('[0x49d4:1:0x0b04]: Message send failure'), TimeoutError()]
EDIT: I think I was wrong… it seems like it crashed this morning according to system monitor on Grafana so I have no logs for that moment, or I have no idea how to get them.
EDIT2: Looking at a temperature trend, I saw that the last data point was at sunrise so I am guessing that something I am doing at sunrise is causing it to crash. Most of what I do is now in Node Red so I’ll hunt there but I am not aware of any NR logs. Are there any?
Same issue here.
HA crashes 2 times, one time somewhere in the middle of the night, and one time early in the morning.
I have no idea how to get a log file, so I don’t know why it was crashing.
This morning I make the upgrade to 2021.10.6 and will see if it fixed the crashes.
@complex1 There may be better, longer logs somewhere but the ones I use are found under Supervisor / System and then select the Log Provider you need. The logs pasted above are from Core.
If you create a GitHub issue and tag me, I will take a look.
@amelchio A lot has changed since I posted above. I moved from an RPI4 to a Proxmox VM on a Lenovo M920q Tiny Desktop PC (i7-8700T / 32GB RAM / 1TB SSD) that for now is pretty much only running HA. The LIFX related logs have decreased significantly but that may be due to another things I did…
  1. I had referenced the “broadcast” IP in my configuration file for about 30 IPs that are reserved for LIFX even though I only have about 20 LIFX bulbs. I commented out the IPs that are not active in case that was causing issues. My bulbs are on a separate VLAN which is why I needed to add the list otherwise HA will not find them.
  2. I had 3 broken LIFX bulbs that I could not get rid of in the integration (That REALLY needs to be fixed!!!) so I took the brute force approach of deleting them from the device file in the config folder. I wonder whether those bulb entries were causing HA to complain.
  3. I am still terrible at VLAN routing but I tried to make a few changes on my Unifi’s settings to favor LIFX operation. I really need to brush up on this as I am quite certain I have no clue what I was doing :wink:
  4. I still have a couple annoying LIFX Z led strips that keep dropping from the wifi network even though they have 3 APs in close proximity (one on each side and one on floor above… wooden houses…). I even tried to lock it to the best AP but it just keeps coming and going. This is causing LIFX errors but at least it references the bulbs. Example:
2021-10-21 09:15:36 WARNING (MainThread) [homeassistant.components.light] Updating lifx light took longer than the scheduled update interval 0:00:10
2021-10-21 09:15:36 WARNING (MainThread) [homeassistant.helpers.entity] Update of light.kitchen_counter_middle_light is taking over 10 seconds
Thanks for offering to help! If the errors pop back up now on this new system, I will create an issue.
Oh … that sounds more like network configuration issues so probably keep it here in the forum after all :slight_smile:
You can still tag me if you do create a new thread.
