Home Assistant 2022.7.0 - Error doing job: Task exception was never retrieved
I’ve started getting these exception in the HA log every ten minutes, 9.10, 9.20, 9.30 etc. No issues with the previous version, which was (from memory) 2022.6.6. Any ideas here, other than rolling back to the previous version?
2022-07-07 20:40:16 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
  File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/helpers/update_coordinator.py", line 151, in _handle_refresh_interval
    await self._async_refresh(log_failures=True, scheduled=True)
  File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/helpers/update_coordinator.py", line 283, in _async_refresh
    self.async_update_listeners()
  File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/helpers/update_coordinator.py", line 110, in async_update_listeners
    update_callback()
  File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/helpers/entity.py", line 532, in async_write_ha_state
    self._async_write_ha_state()
  File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/helpers/entity.py", line 572, in _async_write_ha_state
    attr.update(self.state_attributes or {})
  File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/components/weather/__init__.py", line 698, in state_attributes
    if self.forecast is not None:
  File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/components/openweathermap/weather.py", line 145, in forecast
    forecasts = [
  File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/components/openweathermap/weather.py", line 146, in <listcomp>
    {ha_key: forecast[api_key] for api_key, ha_key in FORECAST_MAP.items()}
  File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/components/openweathermap/weather.py", line 146, in <dictcomp>
KeyError: 'templow'
same for me… I also tried to re-configure openweathermap but it´s still the same
Same here, these started when I updated HA to 2022.7 in the noon today
First occurred: 12:41:55 (22 occurrences)
Last logged: 16:11:56
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 151, in _handle_refresh_interval
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 283, in _async_refresh
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 110, in async_update_listeners
    update_callback()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 532, in async_write_ha_state
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 572, in _async_write_ha_state
  File "/usr/src/homeassistant/homeassistant/components/weather/__init__.py", line 698, in state_attributes
  File "/usr/src/homeassistant/homeassistant/components/openweathermap/weather.py", line 145, in forecast
    forecasts = [
  File "/usr/src/homeassistant/homeassistant/components/openweathermap/weather.py", line 146, in <listcomp>
  File "/usr/src/homeassistant/homeassistant/components/openweathermap/weather.py", line 146, in <dictcomp>
KeyError: 'templow'
Bug logged : https://github.com/home-assistant/core/issues/74665
Seems to be fixed with 2022.7.1
Interesting, thanks. I might give it a week or so before I upgrade again, just so the bugs can be worked out.
I am not sure if I should start a new thread for this. But I might have a somewhat related issue. Though I suspect it is to do with the Tesla intgration and nothing to do with openweathermap as I suspect I do not run that.
I am getting the following errors in the /config/home-assistant.log log file every 10 seconds or so :-
File “/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py”, line 151, in _handle_refresh_interval
File “/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py”, line 283, in _async_refresh
File “/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py”, line 110, in async_update_listeners
update_callback()
File “/config/custom_components/tesla_custom/tesla_device.py”, line 129, in refresh
self.tesla_device.refresh()
File “/usr/local/lib/python3.10/site-packages/teslajsonpy/homeassistant/charger.py”, line 121, in refresh
self.__maxrange_state = data[“charge_to_max_range”]
KeyError: ‘charge_to_max_range’
I also have some other issues with the Tesla integration that has appeated in the last few days. eg the “Battery %” sensor is not always showing “unknown” where it once reported perfectly.
Admins, if I should post this as a new topic relating to Tesla, please let me know.
Further to the post above, I should clarify that I am running :-
Home Assistant 2022.10.4
Supervisor 2022.10.0
Operating System 9.2
Frontend 20221010.0 - latest
So all up to date.
Further to my issue above, I believe I have found a workaround (if not a fix).
I have had a “Control” called “Maxrange switch” enabled (not sure if that is something I did, or it was a default). I disabled this, and my error message went away, AND the battery % came back. So I think that has addressed it for me. Though not sure if this Control should be available or needs to be fixed??
I’m getting Error doing job: Task exception was never retrieved
5:01:26 PM – (ERROR) components/hassio/init.py
Error during setup of component hassio
4:56:26 PM – (ERROR) components/hassio/handler.py
Can’t read panel info: System is not ready with state: setup
4:56:26 PM – (ERROR) hassio
Can’t read Supervisor data: System is not ready with state: setup
4:56:26 PM – (WARNING) hassio
Not connected with the supervisor / system too busy!
4:56:25 PM – (WARNING) hassio
Only rolling back cures this.
