Home_assistant 404 not found
Hey all,
So I’ve been trying to setup HA and google_assistant but have been hitting a brick wall.
I’m running HAOS with supervisor and pushing it through an NGINX reverse proxy.
I believe the issue is that the URL: https://ha.myDomain.com/api/google_assistant results in a “404: Not Found” error. I tried hitting it directly using the IP address: http://192.168.0.14:8123/api/google_assistant which returns the same result so I don’t believe it’s a proxy issue. The /auth/authorize URLs still behave as expected so I believe its something related to google_assistant specifically. Is there a step i’ve missed like enabling the google_assistant addon or something?
I’ve searched around and not been able to find anyone having a similar issue. Does anyone know why this might be happening?
Did you already set Google assistant in your config? The url won’t work until that is complete and after reboot.
That was it, I jumped the gun without putting the config in.
hmm, in my case the google yaml config is loaded, but when i browse to :
https://xxx.duckdns.org:8123/api/google_assistant
i also get 404 not found , verry strange
any idea?
google_assistant: !include google.yaml
and in google.yaml
  project_id: !secret google_proj
  service_account: !include hassio-xxx.json
  expose_by_default: false
  report_state: true
  entity_config:
hmm, seems if i rollack to 2021.12.x , i get back 405 , so can link again
if i update to 2022.2.1 , i get 404
what do you get now on release 2022.2.x ?
Hi
did you find a solution? I have the same problem
This thread 2yrs old
It may sound the same but 2 many changes since then. You need to provide details
Logs
How you test
