This is an Pangolin Newt addon for Home Assistant.
About
Pangolin Newt
Newt is a site/client connector for Pangolin.
It treats networking and security as a single system. Identity, sites, access control, privileged access, and an identity-aware AI gateway share one policy model. The idea is the same as platforms like Cloudflare One, Zscaler, and Prisma Access, but Pangolin is open, self-hostable, and built to stay light enough that administrators actually enjoy running it.
This addon has several configurable options :
- Pangolin Endpoint
- Newt ID
- Newt Secret
- Ability to add extra environment vars
Installation
- Add the Hass.io add-ons repository to your home assistant instance.
- Install this add-on.
- Click the
Savebutton to store your configuration. - Search and add
Newtfrom the addon store. - Configure, then start the add-on.
- Check the logs of the add-on to see if everything went well.
Support
You can open an issue on GitHub, in case you ran into a bug, or maybe you have an idea on improving the addon:
