Home Assistant Addon: Pangolin-CLI
This is an Pangolin-CLI addon for Home Assistant.
About
Pangolin-CLI
Pangolin-CLI is a site/client connector for Pangolin.
It treats networking and security as a single system. Identity, sites, access control, privileged access, and an identity-aware AI gateway share one policy model. The idea is the same as platforms like Cloudflare One, Zscaler, and Prisma Access, but Pangolin is open, self-hostable, and built to stay light enough that administrators actually enjoy running it.
This addon has several configurable options :
  • Pangolin Endpoint
  • Site ID
  • Site Secret
  • Ability to add extra environment vars
Installation
  1. Add the Hass.io add-ons repository to your home assistant instance.
  2. Install this add-on.
  3. Click the Save button to store your configuration.
  4. Search and add Pangolin-CLI from the addon store.
  5. Configure, then start the add-on.
  6. Check the logs of the add-on to see if everything went well.
Support
You can open an issue on GitHub, in case you ran into a bug, or maybe you have an idea on improving the addon:
You might consider changing the name to App as new users may not even know what an add-on is.
Also here’s a thing to help you build My links within HA to help your users load Apps easily. My Link / EZ-Button to help users install your App
