Hello, fellow torrenters! Having a problem after trying to update to 5.1.4-7
Update ended with error
2026-02-05 13:34:48.700 ERROR (MainThread) [supervisor.addons.addon] Add-on db21ed7f_qbittorrent has invalid options: does not match regular expression ^\w+\.conf$.
Addon is not starting, says invalid configuration. Please help.
Config file name is more restrcictve now. Iāll look to change back to how it was
Sadly, after updating to 5.1.4-8 i get error when trying to start addon
does not match regular expression ^[A-Za-z0-9._-]+\.conf$.
Maybe there is smth wrong with my setup? To be clear i never used vpn with my qbt+ha setup.
Ah your wireguard config is null which perhaps causes the issue just type anything and it should go away. Weird
Edit : I meant to type config.conf in the wireguard config field
That helped, thanks a lot for quick response and for your awesome work on this!
Hey Guys
Looking for some idea or help, iām trying to set up Airvpn on the qbittorent addon (openvpn works on it).
Iāve tried changing port, ipv6 / 4 nothing change.
If someone know how to solve that, or have any idea, that would be amazing
[Interface]
Address = xxxxx
PrivateKey = xxxxx
MTU = 1280
DNS = 10.128.0.1[Peer]
PublicKey = xxxxx
PresharedKey = xxxxx
Endpoint = xxxxx:47107
AllowedIPs = 0.0.0.0/0
PersistentKeepalive = 15
interface: wg0
public key: xxxxxx
private key: (hidden)
listening port: 51820
peer: xxxxxx
endpoint: xxx.xxx.xxx.xxx:47107
allowed ips: 0.0.0.0/0
transfer: 0 B received, 148 B sent
persistent keepalive: every 15 seconds
[custom-init] No custom files found, skipping...
crond: crond (busybox 1.37.0) started, log level 8
[12:32:10] INFO: Using Wireguard configuration file: /var/run/wireguard/wg0.conf
[12:32:10] INFO: Starting WireGuard on interface wg0...
[12:32:10] WARNING: This script force Wireguard to ignore any routes and DNS settings.
[12:32:10] WARNING: Default route will be inserted into custom routing table: 1000
[12:32:10] WARNING: This routing table will be used for traffic from the VPN interface and to the configured DNS servers.
[12:32:10] WARNING: Qbittorrent bittorrent client shall be set to use the VPN interface wg0 only.
[12:32:10] INFO: Adding routing rules for VPN interface wg0...
[12:32:10] INFO: Updating /etc/resolv.conf with VPN DNS servers.
[12:32:10] INFO: WireGuard interface wg0 is up.
[12:32:10] INFO: Starting qBittorrent...
WebUI will be started shortly after internal preparations. Please wait...
******** Information ********
To control qBittorrent, access the WebUI at: http://localhost:8080
Connection to localhost (::1) 8080 port [tcp/http-alt] succeeded!
[12:32:12] INFO: Starting nginx...
[12:32:12] INFO: VPN monitor set to query external IP through interface wg0 (interface binding).
[12:32:12] INFO: Real (non-VPN) IP from /currentip: 8x.xx.xx.xx
[ls.io-init] done.
[12:32:12] INFO: VPN detected; enabling IP leak protection and periodic monitoring.
[12:32:42] WARNING: Unable to determine external IP from fallback IP services.
[12:32:42] WARNING: Unable to query external IP (attempt 1/5).
[12:33:17] WARNING: Unable to determine external IP from fallback IP services.
[12:33:17] WARNING: Unable to query external IP (attempt 2/5).
[12:33:52] WARNING: Unable to determine external IP from fallback IP services.
[12:33:52] WARNING: Unable to query external IP (attempt 3/5).
[12:34:27] WARNING: Unable to determine external IP from fallback IP services.
[12:34:27] WARNING: Unable to query external IP (attempt 4/5).
[12:35:02] WARNING: Unable to determine external IP from fallback IP services.
[12:35:02] WARNING: Unable to query external IP (attempt 5/5).
[12:35:07] ERROR: Unable to obtain a VPN external IP different from real IP. Stopping add-on.
if: fatal: unable to spawn s6-test: No such file or directory
Catching signal: SIGTERM
Exiting cleanly
Are you sure your vpn is valid ? I had the same when using an invalid config
Yeah, downloaded directly from airvpn, and same config file is working on my desktop computer
Hi, Iāve bought a airvpn pass and will make it work.
First issue is that airvpn config filenames are more than 15 characters and therefore canāt work. This will be fixed in next version.
Second issue is why it doesnāt connect, I still need to understand and will look a bit deeper
Fixed in latest
Hi @alexbelgium Since the last update, the add-on has been using a lot of CPU (around 67%). In previous versions, it was around 10-12% (at most). Have you noticed this too, or could it be a problem with my configuration? Because the configuration is the same as in previous versions. At first, CPU usage is normal, but after a few hours of running, the CPU usage increases significantly.
Hi, could you could please specify the versions having the issue or not ? Thanks
the version is the 5.1.4-15 but now after Iāve reduced the field about the physical memory ( before it was 2048) to 1024 ( like the default) it seems solved.
never mind that wasnāt the problem because I woke up and it was back at , 68% CPU usage.I use wireguard, could it be due to that?
In the past there were some issues with qbittorrent and I had set an automation to automatically restart the addon during the night ; this might be a temporary solution. Iāll try to replicate on my system
@alexbelgium I tried using vpn_upnp_enabled as I use WireGuard with Proton VPN and the port for NAT forwarding changes, so I thought this option would solve the problem, but I keep seeing the following in the logs:
[11:51:45] INFO: qBittorrent SessionID not set, getting new SessionID
[11:51:45] ERROR: Failed getting new SessionID from qBittorrent
[11:51:45] ERROR: NAT-PMP/UPnP Failed
How can I fix this? Is it a configuration issue on my end or a bug with the feature?
Iāll push a new version that should solve it now
