I have very limited experience with linux and am not a ‘techie’ by trade, just more of a tinkerer…
I bought the HomeAsisstant pre-flashed from ameridroid and managed to break it’s functionality last night when I tried to add DuckDNS. I was attempting to add this so that I could set up my Nest products. It appeared this is what I needed to do.
Now whenever I try to access HA locally or via the domain name generated by duckDNS, it just sits there and won’t connect. When I attempt to connect via the iPhone App, I just get an error screen that says “no http.base_url was found in the discovery information”.
I found a post from April of 2020 but now I’m not sure if it is out of date because that’s well over a year ago - something about using Nginx to set up DuckDNS?
Does anyone know if that is still the way to go? Thanks
And at any rate - what is the easiest method to undo what I’ve managed to mess up so that I can actually access the interface again?
I just discovered I can get to the HA via the direct IP address. I can take a look at Nginx but after installing visual studio code, the issue appears to be that in my configuration.yaml file, the base_url string “does not match the pattern of deprecated”.
I found another post in the forums about it but even after reading through that I’m not sure what to change.
Thank you, I found the information for internal and external URL… and there’s no option for internal and external URL under configuration - general. I don’t think this is an old version of Home Assistant… not sure why it doesn’t show as an option, I will keep digging.
Thanks for all your help with the basic things that should be obvious. I got that set up, think I got the internal and external access URL’s set up and edited the configuration file for duckDNS domain and token… did mariadb and nginx… Still not quite working but I will try to work on it this afternoon. Thanks again.
