Home assistant and evcc config error
I have been running Home Assistant for a while with various integrations. I use the DSMR integration to know the consumption and the injection, which I then use for smart charging my EV, but I wanted to try it with EVCC. So I installed EVCC via HACS and connected my Alfen charger.
So far, everything is fine. Now I want EVCC to connect to Home Assistant to read the consumption and injection, but I’m stuck.
When I choose Home Assistant for the meter, I get a pop-up with a button to prepare the connection. It opens a new Home Assistant screen with the login credentials and the message that http://xxx.xxx.xxx.xxx:7070 needs access, but it doesn’t work. I can’t log in. Logging in with the same credentials on port 8123 is no problem.
Does anyone have an idea?
Since you use :7070 it seems you're connecting to evcc. Try the evcc password
