Home Butler will automatically discover all the devices registered in your Home Assistant system. However, current version only supports these types and actions:
The app unfortuantely doesn’t work for me… I set up the token, open the app on my watch and then it crashes after like 10 sec. Any ideas what might be wrong or how to debug? I don’t see any errors in HA and I do have a valid Let’s Encrypt certificate for my custom domain as well.
Got this from developer
Sorry for the delay. 2020 is not easy on me…
The bug has been fixed. I was caused by a Home Assistant’s API change,
which was not announced publicly… New version is under review by
Fitbit Admin.
Hi, the document link is broken. I’ve tried anyway to download it on my FitBit Versa, but I don’t know how to configure the app to let it work with HA.
Hi! Thank you very much for this app! Unfortunatelly I still can´t it get working: I installed it and tried to setup the settings, but when I sync and try to open the app on my fitbit it just says “please configure your Home Asssistant settings in the fitbit app”. Do I use the right settings?
I seem to get a error in HA after inputting the correct info in the app on the phone:
“Login attempt or request with invalid authentication from 192.168.1.226 (192.168.1.226) (Fitbit/3.36 Android/29)”
A new version (v2.0.1) with new UI design (which I have to make because of the SDK 5.0 incompatibility issue). It’s being reviewed by Fitbit App Gallery admins. Should the available in a few days.
Thanks @heqian for the update, works quite well in my Versa 3!
Maybe it’s a bit too sensitive to scroll events when tapping to an icon though, and would be nice a status indicator (like a spinner when request is in progress).
Question: could you consider releasing the code as open source? A part the ethical implications, I’d like to help in contributing to it and I guess other people in the HA community could, in order to improve the devices support!
