I have a few automations. Thinks like automating lights and telling me when the garage door goes up and down. So, I’m not a complete newbie, but close. I started testing a motion sensor and the automations I could do with it. The idea is that I put it somewhere that it can watch the gate into my backyard and if someone comes in my yard at night that it warns me.
The first section of the automation creation is the “When”. The motion detector becomes occupied and it triggers the automation. This part seems fine
The second part is the “And if”. I have played with this and can get it to filter based on time or the sun or whatever. This part also seems fine.
So then there’s the “Then do”. One option is to buy another Sonos speaker. These are always on and I can set the volume and put the speaker close to the bed so that it’s more likely to wake me up. I have gotten it to work with the Sonos speakers on the TV in my main living room. That seemed OK because it was just one Action.
Then I started playing with getting it to play to the TV in my bedroom. So, I played with the notifications and the Media Player action. I learned that it will actually turn the TV on. And I can send it a message and it will TTS the message. The TV will announce “motion detected in back yard”. But the first time I trip the sensor, the TV will not be warmed up enough to play the TTS in time, so it’s lost. The second time I trip the sensor, the TV is warm and it will play. So I started looking at the things you can do in Media Player and you can turn it on/off, set the volume up/down. So I thought I would make 4 actions to Turn On, Set Volume Up, Play the message, Turn it off. And maybe put a pause in after Turn On.
What happens, however, is that I go into “Then do” and click Add Action. The select Media Player, and then Turn On. The pop up clears and it goes back to the main screen and wants a Target. So, I pick “Choose device” select the TV in the bedroom.
That does well and I click Save and then go back to add another action. I select Media Player like before and select “Turn up volume”. It then wants me to select a target, like before. But when I click Choose device, the TV is not there. The other TVs in the house are there, but not the one in the bedroom from the first action.
Why can’t you send multiple actions to the same device? Is there another way to solve this?
